41 - 60 of 62 Posts
My truck was also....
pistonpete said:
After reading these posts, I was curious to see when mine was manufactured. I picked up mine on Februray 13 and the born on date said 02/04.
I guess you could say mine was fresh out-of-the-oven when I got it.
Exactly, My truck was born on 2/19 and I picked it up on 2/26... still toasty warm......LOL.
Build date 04/04, VIN# 540061, purchased 4/21/04
KC Red Brawn 4x2, SE Popular Pkg Captains, Splash Guards, Bedliner, Floor Mats.
No problems. I am still trying to figure out the problems people are having with the radio to determine if I've got it. There is a new radio station in town where I get real crappy reception. The others seem fine. I like the SSV because I like to drive with the windows down (my other car is a convertible) so it's nice to have the volume adjusted for me.
this may sound dumb, but how do I found out when my truck was built??
Open the drivers door and look for a sticker. At the top of the sticker it will show something like "Manufacture Date" and it will give MM/YY (04/04 was mine).
yeah i just checked the driver's door didn't see any sticker showing any type of manufacturing date.....
If you dont have a sticker, the dealer should be able to tell you the next time you take it for service.
Really? That's odd. I snapped a couple pictures. It only says Date at the top of the sticker.
superdave said:
Born on 11/03
Last 6 502839
Mine was born 11/03 last 6 of VIN are 502868 yours was made right before mine!!!
Jeff
I found a partial manifest on the floor of my truck containing a bunch of bar codes. It shows
Manifest Printed 03/22/04 14:34:43
Assigned : 03/15/04
Due Date: 03/25/04
Appr Shop Date 03/22/04
Door shows 03/04
Sticker shows 03/22/04
It would appear that it takes about 7 days to build the truck.
I did find it by the way. just didn't look very hard. lol
well just checked mine.
door sticker 02/04
window sticker says 20040224 at bottom
now i bought mine 3-28 and the dealer said it had only been on the lot 15 days. so, this leads me to believe that the 2/24 was a manufacture date b/c i doubt it would take 15 days to get to dealer. i dont know. just a thought. but definately a feb build.
this truck is the SH!T
steve
Finally checked my info and found the following:
Last 6 of vin: 526748
Date on Door jamb: 2/04
Date on Window Sticker: 2/25/04
4/04 build still has crummy FM.
We just took delivery on our SE, popular package, 4wd, towing and offroad. It's the plain-Jane 6 cd changer, non Rockford Fosgate system. Build is 4/04 (hot off the press!) .. FM reception is horrible, just like everyone says.
I thought this only affected the Rockford stuff. Perhaps the head unit is identical?
Regardless, one would think the factory would have installed a "good" radio if they had the fix.
I can't see this being a software issue, although I know software tuners exist. These mass-market stereos likely don't have ICP or JTAG, so I'd be pretty shocked if the dealer can just pop the radio out and connect a computer to it and "fix" it.
If Nissan is actually going to take care of us, I think they'll have to swap out radios, or send them off somewhere to have someone update the flash or replace a component or two.
If someone has removed the radio without causing any physical damage to the dash, I'd appreciate a pointer or two. When the fix comes available, I suspect my stereo will experience a well-timed simple-to-repair failure so it gets replaced with one that doesn't stink.
Thus far, with 200 miles on the truck.. no other issues. Brake pedal is firm, so I guess they solved the master cylinder issue, at least for some 4/04 builds, although it could take some time to develop..
All-in-all, a fantastic vehicle, and just some minor first-year issues in the grand scheme of things.
-Steve
Assigned : 03/15/04
Due Date: 03/25/04
Door shows 03/04
Vin 535585
Hey Dude - you and I are fairly equal mine is 532XXX and says 03/04 We have the same truck but for color and step rails (oh and i threw the banks on), but everything else is the same.
Curious what is your gas mileage like? city and highway.
I have only filled up once so far. I got exactly 10.0 mpg all city driving. I am due to fill up my second tank in a couple of days. It looks like I am still in the 9.5-10.5 range. Hopefully, the gas mileage will go up as the truck gets broken in.
stevemis said:
If someone has removed the radio without causing any physical damage to the dash, I'd appreciate a pointer or two. -Steve
Download the Service Manual for $20 and take a look at pages IP-12 & AV-65
In a nutshell:
IP-12: Pull the center dash cover section rearward. It is just held by clips. Then disconnect the electrical connectors to the heat & A/C control knobs. This allows removal of the center dash cover.
AV-65: Remove four screws (two on each side) pull the audio unit out and disconnect the connectors.
I have had the center dash cover off. It is not that big of a deal. Just grab it at one upper corner and pull.
41 - 60 of 62 Posts
