Bestatchess, you are awesome.
I had no idea the manual was downloadable. I signed up for a day, then found the main PDF.. I did some searches here and found a list of filenames for each chapter and wrote a shell script (I'm a programmer) to pull everything down to one of the machines at work.
It's downloaded, and I just started the monster print job at work. I'll head in tomorrow morning and either pick up a gigantic wad of $19.99 service manual, or feed the printer more paper!
This is all going on 2 CD's - one to put on the shelf, and one to use.
These Nissan people.. pretty darn slick.
Thanks again for the tip!
-Steve
bestatchess said:
Download the Service Manual for $20 and take a look at pages IP-12 & AV-65
In a nutshell:
IP-12: Pull the center dash cover section rearward. It is just held by clips. Then disconnect the electrical connectors to the heat & A/C control knobs. This allows removal of the center dash cover.
AV-65: Remove four screws (two on each side) pull the audio unit out and disconnect the connectors.
I have had the center dash cover off. It is not that big of a deal. Just grab it at one upper corner and pull.
