1 - 20 of 27 Posts
I was hoping I could get some ideas from you guys on mounting my bull bar lights. I have a Hunter bull bar and the brackets that came with stick out way too much (like 4").
I took some 90 degree alumimum which is 1/8" thick, cut it to about 2" long and mounted that to the bar and the lights on top of it. They look fine but the aluminum is too thin so it has flex in it and the lights will bounce over road imperfections.
Anyone have any ideas for a non-rusting mounting solution?
Thanks!
I bent the brackets it came with. Flattened them out, mounting the brackets so they stuck straight up, drilled new holes for the lights and then a heavy dose of bedliner.
Do you have any pics of that setup? My lights mount from the bottom but they do have a swivel bracket so I suppose they could be mounted vertically.
Here's a diagram of the lights:
Thanks for the link. So did you just mount the lights by turning the connector 90 degrees like so:
From the pics it looks like there is part of the light touching the bar, is that a bumper or just part of the mount?
Nice - I got just the one :)
Drilling it is gonna be a PITA though - the aluminum took forever which leads me to beleive it's time for a new drill bit...
To mount my KC Daylighters to my winch mount I had some steel angle brackets fabricated and powder coated. Mine are pretty stiff but I suppose a small amount of flex is a good thing as it keeps the lights from being shaken to pieces.
Discussion Starter · #14 ·
Where did you have that done? Metal shop? How much?
I had it done through ShortRunPro.com. I had them fab up 3 pairs and the total was just under $150. I made extras because I thought was going to mount more than 2 pairs of lights and then maybe sell a pair of the brackets. Attached is the CAD design they made for them.
Discussion Starter · #16 ·
Thanks for the info. What bull bar are you running? The Hunter I have has the mount screws for the bracket horizontal.
I have the Mile Marker winch mount. The light brackets are attached to the vertical portion of the winch mount. The brackets are kind of hard to see in this photo.
Image uploading. Refresh page to view
Discussion Starter · #19 ·
That's a cool setup :)
I will try to hammer my factory ones flat and if that doesn't work I'll sketch out a drawing and send it to that company. Looks like they will provide a free estimate and I would be curious to see if they could do them in stainless steel.
Go through their design application on their web site. No need to draw it.
1 - 20 of 27 Posts
