1 - 6 of 6 Posts
When the temperature is at or below freezing the Brake Warning Light and the Slip Indicator Light at the dash comes on. My truck is a 2014 Pro4X Cew Cab with about 65k miles. The brake fluid is not low. I upgraded the brakes and rotors to EBC about a year ago and flushed all of the fluid and replaced it with a vacuum pump. So there souldnt be any air in the lines and the pedal feels normal.
Has anyone else experienced this or have any idea how to correct it? Thanks.
Would that make the light come on since the parking brake isnt being used? I replaced the brake shoes also with new Power Stop brand.
Discussion Starter #4
The lights came on this morning after driving about 10 or 15 miles in 34 degree. We have had alot of rain in the last few days and now that i think of it, I think we had wet weather when the light came on in the past also.
The traction control and ABS light may be functioning properly if you're getting tire slippage on the road. Both utilize the wheel speed sensors and trigger the light if road conditions cause wheel slip.
1 - 6 of 6 Posts
