So I just watched this video on you tube on replacing my brake booster.. Is this correct method? Will I need to pull the wiper motor and trim parts? Will I be able to get enough room to pull out the booster if I don't do that? Also , will I gain enough access if not disconnecting the supply lines to the abs?
Thanks
