1 - 2 of 2 Posts
If the controller is working manually, the fuse isn't your issue. Perhaps the controller is bad. If you have brake lights and the controller works in manual mode, then the truck portion of the system is fine unless you broke a brake specific controller wire under the dash at some point.
1 - 2 of 2 Posts
