I am installing a brake controller in my 2017 pro 4X and would appreciate some input as to the location to mount it. Of course out of the way but convenient where you can read it and use it when needed. Thanks
Steven
· Super Moderator
Down by your right knee if you've got the leg room.
I mounted mine directly below the steering wheel (shin region) , using two self tappers, attached to the flat part of the plastic shroud. Keep in mind, some controller's need to be mounted "level" and not on any angles to work properly. Ck you instructions prior to install.
most modern brake controller these days can be mounted at an angle with no issues, but you should be able to adjust the controller when moving and be able to use the manual brake feature of the controller while driving
My Prodigy P3 is mounted just to the left of my right knee. I can get to it easily with my right hand.
