1 - 10 of 10 Posts
I'm probably going to mount my brake controller near my right knee. What I'm not sure about is if it's better to mount it to the dash plastic or to the metal underneath.
My concern about using the metal is the controller may be too far to reach while driving. At the same time, I'm not really excited about drilling holes into the lower dash.
From the various pictures I've seen of installs I can't tell if most people are attaching to the dash or to the metal brackets.
What about 3M tape
Good question!
If I ever get around to installing one someday, I'm gonna have a tough time deciding because of my long legs getting in the way.
One thing to remember is the angle the brake controller is mounted at. Some have limits that may prevent mounting on the plastic part of the lower dash panel. In general, the more level it is the better.
I selected a location near the BCM plug. Now I just have to get the screws into the P3 tight enough so it doesn't wobble.
So I am new to the whole electronic brake controller and such. My truck is used and already has it mounted at the right knee area but was looking at getting creative with the mounting one day soon, like trying to put it upright onto the side of the center console area. My question being, why is it better for it to be mounted more level?
Older type brake controllers needed to be mounted level (for whatever reason) but the newer electronic brake controllers may be mounted in any position, even sideways. Some brake controllers will even state on the packaging that they can be mounted in any position (mine did).
The older brake controllers used an electro-mechanical device to detect decelleration. If they were mounted too far from horizontal, the either didn't work very well or not at all. Even some of the newer electronic ones still have limits. I know that my Prodigy can't be tilted more that 70 deg from horizontal. I would try to find the manufacturer and model of brake controller you have and go to the their website and see if they have installation instructions available.
Discussion Starter · #10 ·
The only limitation on the P3 is it has to be in the direction of travel. I didn't find anything about angles.
1 - 10 of 10 Posts
