1 - 20 of 29 Posts
I will soon be adding my Tekonsha Prodigy Brake Controller to my Titan equipped with the tow package. Has anyone else added a controller yet? I am trying to decide where to mount it (I have captain seating). I cannot mount it at more than a 70 degree angle, per instruction. Any ideas, or experience?
Here is where I put our Prodigy controller. I doesn't get in my way and I can see the controller readings and apply the trailer brakes just fine.
Have you found the connector under the dash yet? I mounted in front of the parking brake. Or you can mout it in front of the gas pedal, there is a steel beam running across the lower dash.
Picture of Prodigy
In your picture, I can see that the trimming around the radio area is a little uneven - I mean you can see it doesn't stick out at the bottom but up by the top there is a gap. Can you press on on the plate??
In a Titan I tested, it looked like yours , only it stuck out a little more, and I could push it in flush. The dealer and I thought it had to be fixed.
Just curious if this is the design or a flaw.
Did you find a good deal on your Tekonsha Prodigy Brake Controller?
Brake controller
Did you pick up a connector made for the Titan or did you just wire it in to the connection that is supposed to be provided at the dash by Nissan? Did you wire it in yourself or have it installed? If you did it, was it a big job? Did the wire color codes match up?
Norm
Titan LE 4X4
Smoke
I got mine from my camper dealer when I purchased our popup camper. I jsut purchased a second generic wiring harnes and pocket mount, so I will be able to transfer between vehicles if needed. I have seen good pricing on the internet though. Just do a search.
I had Quality Bumper in Phx install my controller using the wiring harness connector provided by Nissan. They only charged me $20, and it only took about 10 minutes to install (they were really impressed). If you are not use to wiring controller's I would recommend having someone that does this for a living perform the install as you can burn up the computer in the Prodigy if you're not careful. RV Wholesaler's is the least expensive place I have found for towing equipment and accessories.
Karl
And I thought I was picky...
Karl
It doesn't look bad. It actually looked like it was designed that way. I just happened to be reaching for the volume while I was driving and pushed against the plate. It pushed right in and clicked as it hit the back. That is why I noticed it. You could tap it with your finger and the middle part would go flush and click like it just wasn't fastened. That is why I asked if yours did that too. I wanted to know if it was supposed to be designed that way or it was suppose to be flat.
I'm not sure keane but I'll have to give it a try a see.
Karl
Brake controller
Karl
Thanks Karl that is what I needed to know!!!!!
Norm :cheers:
I have a Prodigy Brake controller with the generic harness. The Tekonsha harness has four wires on it, but the Titan has a seven wire plug to tap into. Which wires on the Nissan harness go to the brake controller?
I took it to a hitch place and had them connect the wires together. ($10) He left two wires out, but I can't remember which ones. I mounted it myself, and plugged it in. Works great.
I did not use the quick disconnect cradle supplied with mine as I only have the one truck to use it in. As you can see in the picture, I simply mounted it to the right of the steering wheel, up high enough so that I would not damage my shin.
Anybody know which 4 out the 7 Nissan wires are used for the brake controller?
I just went out and pulled the wires down. The only one I can see left out is the Red/Blue colored one.
Search the site...your answer is here. I found it but I can't remember so just search and you will find the colour answer
Call Tekonsha
I called Tekonsha, the folks that manufacture the brake controller. They'll tell you which wires go where. The instructions w/my brake controller were for Chevy, GMC, Ford, etc. Nothing for the Titan of course.
1 - 20 of 29 Posts
