I tow a 9K lb trailer, insist on being able to stop..... and use Brake Motive rotors front (slotted and dimpled, NOT drilled...), standard rotors in the rear and Autozone semi metallic pads. $29 each axle last time I bought. As good as any EBC or Hawke towing pads I've used in the past. Semi's are organic and will bed and grab better than ceramic, ceramic kevlar or any other 'fancy' pad. High heat racing pads....kevlar or carbon fiber recipe are way overkill for street use and don't work until they're heated up. Ceramics are by design, made to dust in a different color (gray) than semi's so you don't see the grunge on your wheels. The other benefit from semi's....they are less prone to grooving your rotors like ceramic pads do. So, if you want less dust, buy a ceramic. If you're going to race your truck, .....
For the street and you don't care about cleaning your wheels, I suggest the semi metallic or even an old style organic if they're still available!
