Does anyone elses' brakes squeal at low speeds?? I've checked my pads and they're good (wear gauge not rubbing).
This is an ongoing debate on the SRTforums also...most people are going to the EBC or Performance friction pads. Supposedly don't squeal as much and less brake dust. I still have my factory pads on my truck and haven't experienced a squeal....but...the brake dust is ridiculous.z-man said:brake noise is annoying
Your brakes are glazed!! Take the pads off, and put them on a belt sander, and have your rotors turned. It will fix the problem.jason27 said:Well it only really does it at low speeds, like idling through a parking lot, then when you apply the brakes it goes away. i can't figure it out. I wonder if there's some dirt stuck in one of the pads???
That is exactly what mine have been doing for a few weeks. I am taking it in this Saturday to have it looked at. Did you ever get it fixed? What was the problem?jason27 said:Well it only really does it at low speeds, like idling through a parking lot, then when you apply the brakes it goes away. i can't figure it out. I wonder if there's some dirt stuck in one of the pads???
