1 - 3 of 3 Posts
It's a 2004 Titan SE. As it says above the break lights will not shut off without disconnecting battery. Throws a C1116 code for the stop lamp circuit. Removed break switch located at the pedal and lights started on. Happened on and off for about a month but now is constant. Becoming a real bother since this also puts the truck in limp mode and will not run above 2k rpm or downshift for acceleration. I would like to check the stop lamp relay but am having troubles finding it. Both of my manuals say it is located in the box directly behind the battery but this relay slot is open and hasn't had a relay in it since I bought the truck and is labeled VDC on the box cover. However I noticed a relay under the dash beside the BCM that is not called out in my manuals. So if anyone knows anything about this issue input would be greatly appreciated. Thank you in advance
1 - 3 of 3 Posts
