How much up/down, side to side play should a 2005 LE 4X4 drivers side FRONT Diff axle have? I personally would say Zero. But I was told it should have shake. Also, where do Y'all buy a front diff rebuild kit; bearings and seals....Thanks
Both my 06 front diffs had about a 1/4 of play on the driver side cv shaft as does my 08. Normal to have some play there as it's a crappy design by Nissan imo
I had my 06 front diff replaced with a brand new one from Nissan and it had play. They are all Dana axles on the Titan btw.
The way these are (UGH) built. There is going to be some play. Side to Side. Up And Down Play should be minimal but still exhistant. The seals will leak way before there is an internal issue. So dont worry unless.. are you having a issue? I would imagine since you are asking ??
