Bulb Size
44149 11
What is the headlight bulb size for the titan?
1 - 12 of 12 Posts
If I remember correctly
If I remember correctly they are 9005 & 9006. I am hoping to be able to use my HID conversion kit from my Infiniti on my new truck! I will know when I pick the truck up this weekend! I am getting more excited every day!
You are correct sir ;
HB3/9005 & HB4/9006 (pg 8-26 of owners manual).
I use to live in Corpus for a couple years in the early '80s, Mon & Dad still do, nice city.
Bulb Replacement
Does anyone have the steps for exchanging the headlight bulbs out on the Titan? I was thinking of changing to the Cool Blues or a slightly brighter (but street legal) bulb. Thanks,
Bulb Replacement
HEADLAMP (OUTER SIDE), FOR LOW BEAM
NOTE: Reach through wheel opening for access.
1. Turn headlamp switch OFF.
2. Disconnect the electrical connector.
3. Turn the bulb counterclockwise to remove it.
4. Installation is in the reverse order of removal.
HEADLAMP (INNER SIDE), FOR HIGH BEAM
FRONT TURN SIGNAL/PARKING LAMP
1. Turn the bulb socket counterclockwise to unlock it.
2. Pull the bulb to remove it from the socket.
3. Installation is in the reverse order of removal.
FRONT SIDE MARKER LAMP
CAUTION:
After installing the bulb, be sure to install the bulb socket securely to ensure watertightness
Page LT-32 (LIGHTING SYSTEM)
Headlamp Replacement
rrumaner said:
Bulb Replacement
CAUTION:
Thanks for the information!!!
In addition to what rrumaner indicated, make sure to not touch the glass portion of the replacement bulbs with your hands. The body oils will cause 'hot spots' on the bulb and will cause early failure/burn-out. Typically, there is a alcohol wipe included with these bulds to wipe them off before you install them.
How bright are the headlights?
Hello everyone,
I'm still waiting for my Titan to come home, but I'm wondering how bright the headlights are. I never got a chance to test drive the truck at night. I have an Infiniti with the xenon headlights and they are a VERY bright white, almost that blue-white color. Are the Titan headlight similar or are they halogen? Can headlights be switched out to be the super-bright white? Please tell me I can zap the people in front of me!!!!
1 - 12 of 12 Posts
