I know this has probably been asked but I can't find it anywhere. I got my bully dog today and installed it but it never asked for a fuel octane option, am I missing it somewhere. Also does the WOT get turned on or off?
I have it set to regular tune, preformance throttle. I'll have to check if the WOT is enabled or disabled. Anything else I should change? What do you monitor on your screen?
You do not need to go through the install again. Scroll through to "settings". I no longer have my BDGt, I now have UPRev. When I did, I used to monitor my tranny, timing and mpg's.
If you initially did not disable WOT, then yes you need to go through the install. If your only looking to see if it's disabled, then NO. It will show under "settings".
