Just FYI... I read this the other day:
http://www.titantalk.com/forums/tit...nions-my-mudding-titan-truck.html#post1002214
"Yes it is a Kennesaw front and rear bumper and I would like to add that it is probably the most complicated install ever concidering there are no instructions and they do not make mounts for you just the bumper so you have to figure out how to do it yourself. This required quite a bit of welding and additional parts. The front cross member had to be cut out and replaced for a beefier one and much more.
P.S. even though the kennesaw front bumper has a winch slot cut into it and the website says you can mount a winch.....trying to do so with what they give you will result in a complete disaster if you use your winch for anything heavier then 20 pounds without first rebuilding it the winch mount area. "
Someone else told me this though:
"I talked with kyle at Kennesaw and he said that the bumper does come with instructions and that all that is needed is after the chrome bumper comes off you have to remove the metal bumper behind it and drill out two existing holes on either side to make them 1/2" to use the supplied bolts. Lets hope i have a better out come."
Just passing along the info that I've seen about the Kennesaw bumpers.
