Ok, so I did my brake mod last week... The metal toggle switch I used was a 5A toggle and it held a current, but would disengage intermittently when switched "off" (broken current). So, in my not so wise choice, decided to get a LED toggle switch, 15A, and replace the 5A toggle. Wired the 15A up and worked like a charm. Then I decided to run the third terminal to ground for the LED light, right? WRONG! I apparently blew a fuse or relay, because now the shifter is in "locked" mode, and I have no brake lights (like as if you tapped into brake pedal wiring instead). Now I checked my fuses, none marked for brake... Visually checked the Big fuses in the IPDM, none appeared broken... Which Relay controls the brakes, or is there a relay under the pedal??? Any help would be greatly appreciated since now I leave the center shifter cover off and use a screw driver to unlock my floor shifter, as well as it is a matter of time before some [email protected] motorist tailgating me decides to go under my rear end...
