You need the GCWR - Gross Combined Weight Rating. That includes the weight of the truck and the trailer, combined.Hi all, I am new to the forum and in the process of buying a '15 pro-4x without big tow package. The GVWR on the sticker is 7200 and everything I read has towing capacity at 9200. Any insight is greatly appreciated.
I wouldn't use the mirrors as an indicator. I've seen big tow Titans with the small mirrors and non big tow Titans with the larger tow mirrors.The only true indicators of a "big tow" is the bigger mirrors and 3.36 gears. On post 08 Gen 1 Titans the Tow package consists of 7 pin (located on hitch, not in bed), hitch, and trailer brake wiring. But, the tow package does not give you the bigger gears, which in turn gives you the bigger towing capacity. On newer 08-15 (non Pro4x Titans) the bigger gearing comes with the max or supreme utility package. The Big Tow package was only offered on pre 08 Titans and is completely different than the tow package. Tow hooks are standard on all Titans except XE/S models, as well as the Transmission temp gauge, post 08. All Pro 4x's get the bigger 3.36 gears and the diff locker.
Are you sure about that? I thought that the 04-07 off-road package came with 3.36 gears. So if you didn't order the tow package also then you had the standard mirrors, not the tow mirrors. As pointed out earlier, I have no idea about the '08+ features.That is only because the previous owner swapped mirrors. A 3.36 geared truck always came from the factory with bigger mirrors.
You are correct, in my mind I was still referring to 08+. Those early years had so many different configurations that were contradictory to the 08+ models and packages.Are you sure about that? I thought that the 04-07 off-road package came with 3.36 gears. So if you didn't order the tow package also then you had the standard mirrors, not the tow mirrors. As pointed out earlier, I have no idea about the '08+ features.
