Man I hope someone can help on here. I have a 09 Nissan Titan, 2WD, Crew cab. Seems I have some type of issue with the interior lights not coming on with the doors opening.
Couple things I should mention, when you open the doors, the door lights come on, but not the overhead lights. I have tested each of the door switched and they do activate the door panel lights, but not the overhead lights.
I am able to manually turn on the overhead lights by switching the switch to door, or on... But if I switch to door... The lights don't turn off after the doors close (except the door, or step lights... They work properly), so I have to keep the switch in the off position.
Hoping someone has seen this before, and can give me some tips... I have tried all the obvious. I have not pulled the switch out yet, but since the rocker seems to turn on and off the lights manually, just not in door mode.. It would seem the light rocker is fine.
Thanks!
Thanks!
