will the Camburg UCA's work with my DR's (already installed) and the 5/8" spacers from Greg? i don't see why not but i thought someone might know something i don't.
a .625" spacer AFTER the factory 2" that the DR's are set at? or a .625" spacer with stock shocks? i have my DR's set around 2.5" right now. basically why i'm asking is i would like to fit 315/70/17's with no issues while having my DR's around 3" and the camburgs/spacer. sound good?loufish said:The DR's are made for replacing the stock shock with no need for a aftermarket UCA. The stock UCA would tolerate a .625" spacer, so no problems for the Camburg UCA.
You can set the ride height what ever you want, the shock length determines if the UCA/ball joint will be an issue or not.a .625" spacer AFTER the factory 2" that the DR's are set at? or a .625" spacer with stock shocks? i have my DR's set around 2.5" right now. basically why i'm asking is i would like to fit 315/70/17's with no issues while having my DR's around 3" and the camburgs/spacer. sound good?
i did a search and the only alignment problem i found was with bracket lifted titans. someone correct me if i'm wrong.Delta15 said:If I remember correctly a while back alot of people were having alignment problems with camburg uca's
only one application? lol as opposed to 2 or 3??? i don't plan on a bracket lift. i have DR's and plan on spindles.Delta15 said:I assume this is the link you are referring to if not check it out
http://www.titantalk.com/forums/titan-suspension/57117-camburg-uppers.html?highlight=CAMBURG+UCA
Just for a second let me play devils advocate and say your right
Why would you want to spend that much money on a uca that you can only use in one application?
