61 - 80 of 136 Posts
so I went to the dealer since I was close and I paid $1.67 will pick it up tomorrow and I'll take pics of it once I get it and ready to intall.
Wow, I should call my dealer, maybe they have my bulb in stock already too.
Thanks for the update, I'll call them instead of waiting for them to call me as my only chance to do this work is on the weekends.
I am going to have to check this out also. My bimmers have those "mood" lights and they have aftermarket LED pNp ones available (from either one of those fancy schmancy companies for big $$$ or superbrightleds.com).
well here it is it took me about 3 min to put the bulb and the console back up and running, if you have the bulb the whole thing should take about 5 min. make sure you pull the console with care and not to hard once you take the bolts out it just snaps in and out. the pix where taken with the cell cam and hope you can make what the pic shows:)
It's funny how many people never knew it was there. Me being one of those people! I didn't notice it until this thread and I had to hold my hand up to it to even see it.
Does anyone have the LED bulb type equivalent for this F'n bulb?
ok so i played around with mine today. mine would work, but only sometimes. i took it out and had a look. the base of the light is similar in operation to a xmas light bulb, and if you have a bulb with just 2 wires on it you can insert it into the base and make it work. i tried a bulb out of a mini mag light and it blew instantly, so i dug out the voltage reader and its putting out 12v at the contacts.
so.. we need a 12v led with 2 wires like an xmas bulb. or a 12v bulb in general. any ideas?
EDIT: that is them.. the first listing..
http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=/instrument.html
EDIT2: it looks like 4mm that is what size the bulb is.
EDIT3: last one.. i sent them an email to see how i figure out what size i need. I will update when i get a reply.
EDIT4: (sorry) if you hover over the part listing on the schematic on http://www.courtesyparts.com/titan-.../genuine-nissan-parts/body-electrical/264-room-lamp/-c-1244_1245_1281_1290.html it says, 2 per vehicle.. where the heck is the other one?
i found a schematic on the led site that had measurements. I can almost guarantee it is the neowedge-4x the only difference is the base is taller. that shouldnt matter since it was tucked in there pretty far anyway.
so now the next question.. what color, and regular or super bright..
Anyone have some detailed instructions on removing the console?
i have the smaller one since i have a sun roof. there are 2 screws inside the sunglasses compartment, then you just give it a solid tug. there are 2 clips that hold it up. you dont even have to disconnect the wire in order to take out the bulb.
Well done beason!!:redblob":redblob":cool: I just found 'em today also, but wasn't sure what size! I'm going with the Red Hi Power......
I'll bet ya the other one is behind the Bluetooth(activated) light next to the rear window switch!!
THANKS!! and good work!
Just ordered my Neo4-R 's. 1 in regular Red and 1 in High Power Red. I'll be using the low power one to replace the Bluetooth light if I was correct....
