I have searched the forums but cant seem to find the answer to a somewhat simple question. Can I install the PRG SAW or Radflo coil-over and rear shock combo now on my stock 2008.5 XE 4x4 now and a couple months down the road add the PC 6" stage 1 lift and reuse the same coil-overs? I know there are different coilover versions for oem and bracket lift versions but I am not sure what the difference is because the PC lift will work with stock shocks. If anyone knows I would greatly appreciate it or if greg from PRG could chime in. If not I may just save up and have it all done at once. Also if anyone could recommend a good shop in either AZ or CA to do the lift or does anyone know if PRG does lift installs?
