1 - 8 of 8 Posts
Im a salesman at a dealership and my manager is giving me a set of 33x12.50x20s federal couragias m/t for free so who wouldnt say yes to some free tires right? Im thinking of getting a 2.5 level kit for my titan , my titan is a 2wd so not a 4x4 and is a 2006 , i was really just wondering if i can fit those 33s on my titan with that 2.5 level and have no rub and if any just little?
You'll easily clear them depending on what your wheel offset is. I'd say as long as you are stock to around 0 offset, you'll have no issues. Anything more offset than 0 then you'll be looking at a slight PWM most likely.
Ran the Federal MT while I still owned my titan. It was a great tire for the price IMO and held up great even with a lot of highway miles traveled.
You should be fine. 33 is not much taller than 2wd OEM, they are wider though so as long as you don't have some crazy wide wheel or low offset wheel you should be ok.
Fuel makes a lot of wheels, with a lot of different offsets. You need to give specific specs. Going back to my post, if you find one that is listed with a 0 to +25 offset you will be fine. That's stick out a little more, all the way to a stock offset of +25.
1 - 8 of 8 Posts
