depending on your wheel specs it will be very close. You will probably need to do a bit of trimming
I already did some trimming, my 35's were rubbing terribly when I first lifted my truck. My biggent concern is rubbing, it's embarassing when the tires rub in a crowded parking lot on a turn and everybody looks.depending on your wheel specs it will be very close. You will probably need to do a bit of trimming
if you had to trim for 35;s with your 6 inch lift, I doubt you will fit 38;s with just 3 inches more. usually takes 12 inches to clear them.I already did some trimming, my 35's were rubbing terribly when I first lifted my truck. My biggent concern is rubbing, it's embarassing when the tires rub in a crowded parking lot on a turn and everybody looks.
Cool, just wanted to make sure. I'll stick with 37x13.5. Thanks!if you had to trim for 35;s with your 6 inch lift, I doubt you will fit 38;s with just 3 inches more. usually takes 12 inches to clear them.
