1 - 20 of 60 Posts
Hey guys,
Lately there have been a few questions regarding the VKPro, basically what exactly can it do and what can't it do. I hope this helps, and if you still have questions feel free to ask and I will update the lists.
Can's:
Supply an additional 30HP and 40TQ to a bone-stock showroom prep truck
Adjust air/fuel ratio for more power
Adjust timing for more aggressive performance
Sense trouble situations and retard itself
Be installed in less than ten minutes with the plug and play harness
Be removed in less than ten minutes in case of any warranty issues
Leaves no trace of installation...No one will ever know it was in there
Can not's:
Adjust drive-by wire/Wide open throttle controls
Remove speed limiter
Does not have a Map A or Map B
Will not work with 2 degree timing advance
It does require 91 or higher octane. And will not work on 2007's.
will it work with my charger?? lol....lol
so can you run 91 octane one day with the chip, then take it out the next and run 87? or are you required to run 91 all the time?
Yes you would need to remove the module if you want to run 87. As long as the VK Pro is hook up to your ECU, 91 is a must.
I wonder what kind of numbers it will get with 105 ? :idea:
it cannot work with the 2 degree timing advance right?
Discussion Starter #13
Yes you can. If you want to run alternate fuels you would have to remove the VKPro until you have the 91 octane fuel in your tank.
Great details, Kyle! When I told my wife about the 91 octane, she wasn't too thrilled. Then I told her if money is tight one month, and I need to cut costs, I'll unplug the harness, plug back stock, and run 87. When things are back to "OK", run out all 87, plug chip back in, and fill with 91.
Kyle, does this mean that 2007 models are not on the radar screen for a VKPro module? Or will the module be offered if it is determined that the 2007 and 2008 engine management is similar?
The cost difference for a fillup using 91 instead of 87 would be less than $5 per tank.
When times are tight, every dollar counts. My wife works on commission. There are good months and bad. And since our truck has really bad mileage, and I drive a distance to work and back, you can multiply that $5 by 10 = $50.
1 - 20 of 60 Posts
