please disregard: using as a test post...
Great work with the site though, I know I really appreciate it!
nissan tian cars
Engine
VK56DE – Endurance 5.6-liter DOHC 32-valve V8 engine
317 hp @ 5,200 rpm
385 lb-ft of torque @ 3,400 rpm
Flexible Fuel Vehicle (FFV) Technology (Titan FFVs are available in North Central, South Central, Southeast, and Mid-Atlantic regions only.)
Emissions – Tier 2-Bin 5 (Fed); LEV2-LEV (CA)
Continuously Variable Valve Timing Control System (CVTCS) on intake valves
Nissan Direct Ignition System
Platinum-tipped spark plugs
Electronic drive-by-wire throttle
Alternator (130 amps)
Battery (650 CCA)
Heavy-duty battery (710 CCA) – standard on FFV models
P P
Drivetrain
Rear-wheel drive
Switch-operated 2-speed transfer case 4-wheel drive (4WD high – 1.000; 4WD low – 2.596)
5-speed automatic transmission with Tow/Haul Mode
Final gear ratio (2.94:1 – similar to a 4-speed automatic 3.73:1)
Lower final gear ratio (3.36:1 – similar to a 4-speed automatic 4.10:1)
P
4-wheel Active Brake Limited Slip (ABLS) – 4x4
2-wheel Active Brake Limited Slip (ABLS) – 4x2
Electronic locking rear differential
Brakes
13.8" x 1.2" front vented disc and 12.6" x 0.6 rear vented disc brakes
4-wheel Anti-lock Braking System (ABS)
Electronic Brake force Distribution (EBD)
Brake Assist
Suspension and Steering
Front: Independent double-wishbone with stabilizer bar and Dana® axles. (Dana® axles on 4X4 only)
Rear: Multi-leaf with solid Dana® axle
Rancho® off-road performance shocks
Engine-speed-sensitive power-assisted rack-and-pinion steering
LEGEND
P Part of Premium Utility Package
and then... HOW YOU DOIN'???
:rofl:
I have been Postting and haven't had any trouble so far. I will wait and see !
BrucesTitan
I can post just can,t get attachment /pic to go thru always says server misconfigured or server error
How can I disable the window lowering function on the remote for my 2012 Titan?
