I know I need a new drive shaft center support for my '09 2wd my question is: What all do I need to get to do this job in my driveway? and help on the steps?
I found one for $65 on Amazon. Is this all I need? seems too cheap. its Spicer brand, model number: 212258-1x and it just says center bearing and shows the black bracket with rubber and a silver coupling thing. (sorry for the ignorance of parts)
Also, the steps I tried to find to fixing this problem is:
1) Mark objects for position
2) Take off the Joint from where it meets the bearing
3) detach Bearing from truck and pull out from the Transmission
4) beat out/ cut off/ or pry off with claw/ the bearing from the drive shaft
5) grease and slip on the new one
6) reattach.
am I on the right track? or am I going to end up having a lawn ornament because I messed up my truck further?
6) reattach.
