PRG camber bolts is your answer. check them out on prgproducts.com i used oem ones but for that much lift thats what id recommend
Thanks! I now have an excuse to buy aftermarket UCA's, the stockers are slapping the coil buckets(or whatever you call it). I tried grinding them down some; maybe more is required?Yes, I believe those are the adjustable camber bolts. I thought CASTer was factory adjustable? Only other way I know of is aftermarket UCA's
I purchased the lifetime alignment, so I'll keep going back until they get it right:eyebrow:No, they should have NO problem getting the caster correct... I think it was like 2006 or something that Nissan stopped supplying the adjustable CAM Bolts but the PRoComp Kit includes them to replace the OEM junkers... Those boys at the shop just need to work a little harder at getting 'er done, it's no different than aligning a lifted Ford F-150... My alignment Tech had it absolutely perfect in under 2-mins...![]()
