1 - 20 of 21 Posts
From advice on this forum, I called Cajun B-Pipes. Outstanding customer service. When you call, you speak to the owner (nightowl) and he took the time and answered all my questions. Nothing was "pushed" either, I was only recommended and sold the product that fit my needs in what I was wanting to accomplish. Can't say enough positive things about it, truly great experience! So, I bought the 2.25" catless b-pipes. 409 Stainless Mandrel Bent.
The truck: 2015 Nissan Titan PRO-4X. Only has 3200 miles on it so far.
Current Mods: 2 degree timing advance and INJEN intake. I also since day one have only run premium gas. Supposedly the ecm overtime recognizes this and gives a very small bump in power because of it.
When they arrived, I cleaned the inside and outside with some shop towels and Acetone.
Discussion Starter · #2 ·
Next, since I live up in Michigan, (8 inches of snow have already fallen, along with mounds and mounds of corrosive crap put down on the roads......Can't have nothing nice up here! Anyways...) Cajun recommended a good ceramic/high heat product to paint with. I used VHT.
After three coats of primer, and three coats of the paint, I "pre-cured" the pipes using an industrial oven at work. The oven still won't go as high as the top cure temp listed on the can instructions, but I figured if nothing else it will lesson that "burning paint" smell while they cure on the truck. After driving it around over the last couple days, I can confirm that the big oven "pre-cure" helped with that quite a bit.
So I went to my Nissan dealer, and had the Master Tech (who has taken care of all my past Nissan's) put them on. As per Cajun, he used brand new Nissan gaskets, part number 20692-65J00. These were used on the front and rear of the b-pipes. Worked great. Since I have the factory manifolds, the studs from them go into the font b-pipes, anti seize was used (per Cajun) and the new nuts that came with the b-pipes were then used. Cajun's supplied nuts and bolts (again, using anti-size) were used for the rear.
Drivers Side (the longer pipe):
Discussion Starter · #6 · (Edited)
The Master Tech elected not to remove the drivers side O2 connector plastic fastener from the mounting bracket on the transmission. Instead he just spaced out the mounting bracket itself. Both of us were wanting this to appear as "factory" as possible. The main functional theory behind it was that due to the orientation of the green O2 connector at the transmission mounting bracket, by leaving that there and moving the bracket out, the natural "arc" of the O2 wire harness would be maintained, thereby offering the proper clearance for the front drive-shaft. That's the thinking anyways. I'm sure there are those of you who have done this and just removed that plastic fastener, and all was well:smile: There might have been a change (or not) with the drivers side O2 sensor harness in that it may be shorter. I say this because without either removing the plastic fastener at the O2 connector or spacing out the bracket, the O2 harness would not reach.
Great write up, thankyou.
Discussion Starter · #8 · (Edited)
So after all that, the Master Tech gets out CONSULT, resets the idle learn and goes for a drive with CONSULT hooked up to it. He comes back, truck has a "clean bill of health" and off I went. Since the truck has so few miles on it, there was hardly any carbon buildup on the inside of the exhaust piping. Which might explain why after the catless b-pipes were put on, it sounds like I have a very mild cat-back exhaust system on the truck. Basically just a deeper, slightly louder version of the stock exhaust note. It's has a nice rumble to it as the revs climb. Very, very mild drone between 1400-1600 rpms. Really the same factory drone, just louder. You wouldn't notice it unless you were listening for it. I have not had it past 3500 rpms yet, as I mostly have been doing around town driving. No codes, and I have not heard any CIS so far. With just the INJEN and these cat-less b-pipes, the truck is noticeably stronger than when it was totally stock. Now, not like a night and day difference, but more like a morning to noon difference. I have a close to 700 mile round trip coming up, I'll post what my impressions of full throttle applications and such afterwards. I will say that there is a hill that I drive on every day to get home. I'm not sure exactly what the grade is, but anyways when the truck was stock, fully "warm", it would lock the torque converter and pull the hill in OD at 41mph. Any lower than that the torque converter would unlock, and the truck sometimes would downshift. Now, with the bolt-ons, the truck does the same hill with the torque converter locked up at 38mph. With the BT gears, I'm now pulling that hill between 1K and 1100 rpms. No engine knock, no "lugging". Truck is just "loafing" along going up that hill, and my fuel mileage bar in the dash stays in the middle position between "0" and "20". I can even gently push the throttle and (gently) accelerate without the torque converter unlocking or downshifting a gear. Before it would just downshift, no matter how "gently" I pushed the throttle. Seems to me more torque has been found:big_grin: Big thanks to Cajun for recommending these. Great product and fantastic service!
What did that run you for those pipes if you don't mind me asking. I don't think I'd get away with that in PA, but never hurts to check.
If you a referring to getting inspected, you will be fine. The factory exhaust manifolds have a set of cats in them to get you through inspection.
· Vendor
The bpipe cats are not monitored by the ecu so you can go catless bpipes as long as the stock manifolds are in place and the manifold cats are in good shape. Once you install headers due to cracked manifolds custom catted bpipes are needed (Cajun Stage 1 package).
Thanks for the outstanding write up and pics!!!!
Discussion Starter · #18 · (Edited)
So after 14 hours and 930 miles behind the wheel, some notes:
Drone: the worst seems to be right at 1600 rpms, between 56-59mph. It does not resonate the cab, nor is it outright "deaf'ning", but you can definitely hear it when pulling a grade at the rpm/speed. I like the exhaust note so much I can deal with it. If you are going down hill at that speed or rpm it's not really noticeable. Any rpm less or more and it nearly disappears. Keep in mind I have the BT gears.
Rasp/CIS: None that I have heard. There is a very slight bit of rasp when the truck is cold when your first start it up at that "light off" moment, but that's it. After a couple minutes when the exhaust is warm, then is none. Just a nice low level rumble.
Interstate driving: Driving with the cruise set above 70mph, the truck actually seems "quieter" in the cab than when stock. Weird I know, but you just hear this perfect rumble of exhaust (very mild, not annoying) and that's it. Before with the stock configuration, you would hear the factory intake "dull roar" more than anything. On my truck, the IJEN and Catless B-Pipes seem to have the perfect "balance" of frequencies at highway driving, in that bad resonance frequencies are either getting cancelled out or are no longer being produced. Lower speeds you hear more of the exhaust, and when accelerating without a downshift you hear a very nice balance of intake and exhaust. Full throttle yields a glorious, "angry" 5.6 liter VK56DE wanting to put the hurt on something or somebody:big_grin: Again, no CIS and annoyingly "bad" sounds heard. To me, "bad" sounds = "cheap" sounds. Think 1980's small block Chevy with duals from mainfolds back running glasspacks and 2 inch crush bent aluminium pipe for my definition of "bad" sounds.
Fuel Mileage: I have checked my gallons used vs. the miles I've driven. No change. I still average close to 14 or so in town (summer it can be as high as 16) and anywhere from 15 to 19 on the highway, just depends on how fast or slow I am driving. So with the IJEN and Cajun pipes, while I may not have increased fuel mileage (is that really even possible on this truck anyways?) there has been a nice power increase and therefore I feel the truck is more efficient with the fuel it does burn. I was not looking to increase it, as I have been impressed with what it has gotten since I bought it compared to my fuel use experiences based off my 2014 PRO-4X. The best it could do was 12 in town and 15 and change on the highway. So my 2015 PRO-4X exceeded my expectations from the get go.
Overall I am very, VERY pleased with this setup. The truck is very responsive, makes great sounds, and is really fun to drive.
Side note: Is it just me, or is the BT gears the greatest thing ever made for interstate driving? If I wanted to accelerate from, say 65mph to 75mph, 80mph or even more, all I had to do was just sqeeeeeze the throttle. Not downshifting, no torque converter unlocking, the truck would just go. It was fairly impressive actually. The other cool part was, since aerodynamically the Titan is about as efficient as a Blimp Hanger, if I wanted to slow down, even in kind of a hurry from higher speeds, all I had to do was lift throttle. It was like applying the brakes. Guess that's where all the fuel goes when you drive a truck that prefers to "ram" or go toe to toe with the wind above any speed higher than 45mph:big_grin:
Awesome review. I can't wait to get the stage 1 from Cajun.
1 - 20 of 21 Posts
