Are you looking to replace them with OEM cats?
The OEM primary cats is part of the exhaust manifold, FYI
I didnt realize there were 4 on these trucks.Are you looking to replace them with OEM cats?
Im hoping I only need the "rear" ones?What he said ^^^
Umm, yeah, I guess I dont know which ones are bad. How do you tell?
The first set is welded onto the manifolds. The second set can be replaced. Look into Berk Technologies B-pipes to replace the second set
If the truck wouldnt throw codes, I would....No emission test here etiher.Just run with no cats haha. Take all four out. I plan on it. Of course I have no emissions haha.
Looks like I need to do some research.To save a few bucks you can buy the raw cats from the internet and weld your old flanges on if they aren't too rusty.
$1500?! Yes, go for headers and Uprev. It will cost a little less than $1500 and you'll be happier.Looks like I need the fronts. Would I be better off getting headers and a programmer ?
Quote from the stealership is $1500.00
Yep you'd be way better off paying for headers and uprev. Probably cost you almost 1100-1200 for both of those if you get long tubes. If you getbprofessionally installed maybe another 200-300 or you can do it your self. Plus the major gains you will have!!!Looks like I need the fronts. Would I be better off getting headers and a programmer ?
