Center Console Ice Chest
48167 Views 68 Replies 42 Participants Last post by  Eesti
9
Ok so i was really bored yesterday and came up of the idea to turn my Center Console into a ice chest. took some pics for you guys to check it out.
First i took out the 3 bolts out of the bottom and removed the other 3 holding the arm rest door on. then i pulled 2 more bolts out that were under the little plugs on the top.
Then drilled a hole in the floor with a 1/4 in drill bit for the rubber hose to drain out to under my truck.
After that i had to cover the 3 holes in the bottom with some homemade plugs made out of sheet metal and glued them on with weatherstripping glue.
Then drilled a hole in the bottom of the console box and had a little threaded brass fitting that i ground down and glued in in.
Waited for everything to dry and put it all back together
The hardest part was lining up the rubber tube to go through the floor cause its double wall steel on the floor so you have to keep trying till you get it lined up perfect and check under the truck to see if you can see the tube coming out i used another brass fitting to stick in the rubber hose at the end coming out of the truck
Now ADD ICE AND SOME DRINKS AND YOU GOT A WORKING ICE CHEST FOR YOUR TRUCK :cheers:
Reactions: 5
61 - 69 of 69 Posts
took a little bit of time but can get 18 beers with ice in it haha :p... took the pic with my phone when it was a bit dark so quality is ****ty haha
I don't know if you guys are old enough to remember, but the 1977 Dodge Ramcharger 4X4 came equiped with a foam cooler in the center console ,but it had no drain. I remember that I wore mine out.
Freaking Awesome Mod!!!! I'm going to to this mod as soon as it stops raining! Whoo Hoo!
::update:: I just noticed that this is for guys with bucket seats with a deeper center console, I'm sooo bummed
I did this with my fold down front middle seat that turns into a storage container... :p as seen in pic above a few comments
awesome mod bro
How about a Cup holder that heats or cools with a 12v plug in thermo electric ceramic module?(Ferrotec Thermoelectric Modules - Peltier Cooler Model 9504/125/060 B) you would just flip it over for hot or cold and plug it into one or both cig lighters. Then just use the cooler mod to hold your mixers and custom pour mixed drinks and use the two built in cup holders to heat or cool the stainless steel Nissan Mugs.
sounds awesome :p
Best part is that it locks too :p Nobody's stealing MY beer .. Awesome mod!
That's awesome but it's also where I keep my Ruger.
61 - 69 of 69 Posts
