Hi,
I'm hoping someone can shed a little light (pun intended) on an issue I'm having with my new (to me) 2013 Pro-4X.
None of the center console backlights come on. I still get a radio/nav display, but the A/C function button/lights, gear shift and radio button lights don't work. However, if I push an airflow button it will light up. Every other light, inside and out, seems to be working (unless there are some burned out ones in locations that I don't know about).
I know there was an "illumination" fuse under the hood on the older Titans, but that doesn't seem to be there anymore. I checked the obvious fuses and found none blown. This seems like it might be more than just burned out bulbs since the problem is fairly widespread. Right now it's impossible to use the controls at night, which gets a little irritating.
Does anyone have any insights? I've been looking through the FSM's, but haven't found a wiring diagram that specifically lists the lights I'm having problems with.
