Im looking for bilstein 5100s for the front...is shockwarehouse.com any good ? heard a lot of crap about them, also a lot of good ? are they the cheapest ?
also does anyone know if I buy regular length coil overs used can I use them with my fabtech spacer on my bracket lift ??? or is it not safe ???? thanks !
Discussion Starter #2
come onnn nobody ?!?
ya i used shockwarehouse, they were cheap. and ya used coil springs should be good as long as they arent broke ha. You getting 08 coils?
Discussion Starter #4
talking about regular coilovers like icons or drs... not extended ones..
That's pretty much the same I've been reading.. I've also seen alot of posts where ShockWarehouse said they're backordered when PRG was getting the out the door the same day.
As for the 6" spacers on top of 5100's that'll be fine... Greg told me that would be an option for me but I liked the idea of extended coilvers better.
Discussion Starter #6
I know the 5100s will work with the spacer but will coil overs work for the spacers ?
I would assume it might depend on the Top Hats, like which ones are used.
