I have a 05 titan the check engine light in the cluster is burned out dealer wants 1500 for the cluster they say you cant replace the bulb
anybody on here try to or know how to replace the bulb
Is there a "check engine light malfunction" light? :lol:
I believe they need to be unsoldered and soldered back in place like so:
yes but in the cluster they call it service engine soon the light is bulb is burned out I have had the cluster out and can see its burned out but sure if it can be replaced dealer says they have to replace the cluster I would like to just change bulb if possible
You are looking at the wrong thing then if you are seeing a "bulb" that is burned out. The CEL is an LED. It seems unlikely it would burn out, before disassembling your cluster I would have someone with a Consult-II get after it and triple-check that the CEL isn't functioning properly.
There should not be any "bulbs" in any Titan cluster, they are all 100% LED
