Chevy 20's
1685 15
Does anyone know if the factory 20's on the Avalanche and Tahoe LTZ's fit our Titans? I've heard yes and no.
1 - 16 of 16 Posts
I don't know if they would fit or not but... I have a set for sale! They are the 20" polished chrome upgrades. Just incase you were looking!
Price? Pics? Obviously, I still need to find out if they will fit or not. I believe the lug pattern is the same, but I've seen different info regarding the offset and lug diameter.
The bolt pattern is the same, 6 on 5.5", but that's about all I know.
Maybe this info might help!
My cousin has my Off Road package wheels/tires on his 07 Tahoe right now.
No problems whatsoever!
So I don't see a reason why the Chevy's won't fit the Titans bolt pattern
Make sure the hub bore on the chevy rims isn't too small. I tried to get a set of chevy take offs a while back and they wouldn't fit over the hub.
Stock 20" Chevy wheels are 20x8.5" with 31mm offset and 78.1mm hub
Our Titan's stock 18" wheel is an 18x8 with a 25mm offset 77.8mm hub
That said, the chevy wheels outer lip should be 1/4" out more than the stock 18" Titan wheels and will tuck another 1/4" under the truck. (someone correct me if my math is wrong)
Based on that I would say yes, they should work but you need to test fit for break clearance.
As for lug details. Titans use a 12x1.25mm thread pitch, Chevy's use a 14x1.5mm thread pitch. The chevy lugs will not fit our trucks and you need to see if our Titan lugs seat in the wheel correctly. You might need to buy a special set of lugs.
Discussion Starter · #10 ·
Thanks for all the info. One thing I forgot to mention is that I already have the Nissan 20's as they came standard on my 2008 LE. I just like the looks of the polished 20's from the Tahoe and Avalanche better and I think they would look good on my majestic blue Titan (minus the bowtie, of course).
Too bad Nissan doesn't offer the standard 20" with a polished finish.
There are places that can polish them for you I've seen a few people do it but not with a titan wheel.
If the Chevy wheels are "hub centric" they will not work on the Titan because the hub is a different diameter(as already posted) But if they're "lug centric", then they just might...
I would do a test fit first before laying out the sawbucks...
I am out of town until Friday. If you are still interested in the wheels let me know and I can take some pictures and maybe someone can tell you if they will work or not. PM me, that will be easiest. Thanks!
We're talking 1.1mm here and as the chevy hub is larger, they will fit over the nissan hub.
I knew the Chevy hub was larger(but didn't know by how much) and it would wind up being a lug centric fit in the end...
Thanks...
The stock titan lugnuts work on the 16" 2003 Chevy steel wheels that i have my DR's mounted on. The alloy 20's may not have the room for the titan lugs wide shoulder to clear, just get some aftermarket tapered seat lugs for a titan they are smaller in dia. than the stock lugs.
1 - 16 of 16 Posts
