If you were able to increase performance with it dont tell her and see if she says anything about it the next time she drives it.dbolemiss said:
If you were able to increase performance with it dont tell her and see if she says anything about it the next time she drives it.dbolemiss said:I was messing around and hooked cipher up to my oldladies 05 pathfinder.It works as far as bumping the timing.I went back and set it to 15,didn't know if the 6 cylenders could handle the 2* or not.didn't get a chance to do any logs.Might play with it a little more without her knowing.
2* shouldn't matter; just listen for detonation & run decent gas.dbolemiss said:I was messing around and hooked cipher up to my oldladies 05 pathfinder.It works as far as bumping the timing.I went back and set it to 15,didn't know if the 6 cylenders could handle the 2* or not.didn't get a chance to do any logs.Might play with it a little more without her knowing.
