If you get the factory Nissan Titan hitch, it will be a ClassIV, that's the only hitch the Titan comes with...
loufish said:If you get the factory Nissan Titan hitch, it will be a ClassIV, that's the only hitch the Titan comes with...
You can't tow more than 5k without a W/D hitch. Not even if you were equipped with the big tow package.2007 TITAN LE said:I want the ball mount with a rating of 8000 lbs or more with a 2" ball. I do not want a 5000lb ball or the weight distribiting system. Can I get a regular
2" 8000lb ball and mount from Nissan?
What's the tongue weight for that trailer loaded?I think it also depends on what you are going to be towing with The Class IV hitch. I Pull A horse trailer that weight empty about 5000 lbs., But when i'm loaded down with three horse and all the gear it weights more around 7500 to 8000 pounds. i use a class 4 hitch that not a weight distributing hitch and i pull the trailers pefect without any sway and there is no tongue weight issues.
