I had something similar to that awhile ago. Retorqued the lug nuts, and it went away for a few minutes. Then I realized I had a rock in my tire. Check for rocks
Yeah, I checked for rocks, and said I checked the tread in the video, but I forgot to say what I checked for. LOL.I had something similar to that awhile ago. Retorqued the lug nuts, and it went away for a few minutes. Then I realized I had a rock in my tire. Check for rocks![]()
Damn. Well, it could be worse I guess. Ill have to wait a bit. Just moved and need to get my toolbox unburied. Next question - Nissan bearings or something from Autozone?Time for a new wheel bearing bro... I had to switch mine out about a year ago
Got my diff fluids changed and checked out my u-joints. Rear diff oil was pretty clean. The front was nasty. Both joints on the front shaft need to be replaced, with the joint at the front axle having the most play. I also discovered that the pinion seal on the front diff is leaking and the output shaft seal (to front driveshaft) on the transfer case has been leaking. Looks like its time to do some driveline work. I'm hoping the u-joints fix my clicking problem :fingers crossed:I would check the front drive shaft U Joints. One of mine was bad and it made a similar ticking sound you could only hear at low speeds.
sorry for the super late reply. my lugs just needed to be re-torqued. according to the dealer, my wheels were about to fall off. ha.No, that was waayyy louder than mine. What was that noise?
Any suggestions on u-joints? Good, bad, stay away from, etc.? I see NAPA has some for $9 each, and Nissan wants almost $60 each. I don't offroad hardly ever, and if I do, it's just a backroad that may get washed out or something. The only time I really use the 4wd is for snow, so I don't think I need anything super heavy duty.
its a whole wheel hub assembly. $170.00 each from autozone. I'm actually doing mine tomorrow.Yeah, I checked for rocks, and said I checked the tread in the video, but I forgot to say what I checked for. LOL.
