I had a district tech come and fix my truck. He removed the rear diff input flange and lubricated the internal splines at the pinion shaft. So far so good. Said they had the same problem with some 350Z' a while back, must not be getting lubed good at assembley.
Thanks for posting that update Gene. I have an appt next week to get mine looked at, glad they finally solved it for you. I'm sure this info will save me a ton of unnecessary appointments with Nissan!!
Thanks again.
There was a TSB for the G35 and 350Z regarding the clicking. it was regarding a loose axle nut or something like that.
