1 - 3 of 3 Posts
I hit a pothole last week pulling off a paved road onto a dirt road at not fast speed but hard enough that tire hit the inner wheel liner. Immediately after a clunk noise started when stopping hard, or turning sharply. Also every time I pull over our rolled curb into my driveway, when I back out later about halfway down it almost sounds like its popping out of a bind and back into place. I can literally reproduce every time pulling in the drive way and then back out of it. I am assuming tie rod, control arm or something along those lines. The front end alignment is still spot on and doesn't make the noise just turning back and forth while stopped. I visually inspected and didn't see any damage or any leaking fluid or cracked bushings. Wanted to get some thoughts or advice on what next to do before taking to a shop and being charged. The truck is a 2017 Nissan Titan pro4x.
I tore into into it today and realized my passenger side cv axle is lose at the shaft part closest to subframe. Any ideas on how to tighten this or just replace the cv axle? I seen a video on YouTube on an older titan but not sure if it's the same process.
1 - 3 of 3 Posts
