quick story: took the T into the dealer for a pop sound in the steering column area along with some other minor things. everything was fixed except the pop. at the dealer they bumped my idle 100rpms, replaced bank2 manifold (seized 02 sensor)and air/fuel ratio sensor, and took the steering column covers off to look for any obvious damage or something.
problem is now: when i shut the truck off( key in or out of ignition), wait exactly 1 minute, all of the gauges on the cluster move further -0, past empty, past cold, etc then start twitching simultaneously for a few seconds then go back to the normal "off" position. there is also a slight groan sound(not the actuators). picked the truck up from the dealer today and taking it back tomorrow. just wanted to know if anyone had any ideas.
