1 - 15 of 15 Posts
just had my upper control arms replaced and in the process found out that one of my coil springs are cracked so with that being said I'm going to replace both sides so it sits the same on both sides.The question is do i buy strut/spring combo or just the springs? I was just looking on ROCKAUTO website and they have MONROE combos and RANCHO combos or just the springs. Any thoughts ?
Thanks!
Honestly if your going to switch out the springs, might as well do the struts at the same time. Better option would be to swap them out to Bilsteins though, Rancho would be the next choice.
Reactions: Mastermind46
5100's are about $100 each, so slightly more than it would cost with the Ranchos.
Do you have OEM Upper control arms or aftermarket ones? If your running OEM ones than you will have to leave them on the lowest setting. Are you 2wd or 4wd? Most go with the 08+ 4wd springs.
Bottom setting on the 5100's with the spacer, and the moog 4wd springs
His look is going to be different than yours, you already have 08+ 4wd springs on your truck, since your are an 08+ 4wd...
1 - 15 of 15 Posts
