1 - 8 of 8 Posts
Hey i was wondering what everyones thoughts were on upgrading my comp on my truck, what have u guys done?
Discussion Starter #4
whats the difference between there osiris and chyper
Per BBF: http://www.titantalk.com/forums/898890-post9.html
Basically, the cipher is a data logging device that allows you to make minor adjustments to the truck's programming.
The Osiris is a re-programmer that will enable you to do lots more than advance/retard the timing. It comes with the Cipher software as well.
Discussion Starter #6
do u have ti keep the laptop hooked up to receive the benefits or can u plug it in and progrma it and then take out ur laptop or does it have to saty plugged in
Here's the site summary:
http://uprev.com/products/products.html
Check them out for yourself.
And keeping a laptop hooked up is not very efficient or convenient for the most part. You just hook up to do whatever you want, then disconnect and put your computer away.
Like Blackbeauty already stated:
Only time you need to keep the laptop connected is if you are doing data logging with the Cipher. For the Osiris tune, after the ECU is reflashe with performance MAP, it can be unhook.:cheers:
1 - 8 of 8 Posts
