The condensation issue resurfaced, so I removed the lens again today and filled it completely with water to look for leaks.
No leaks, but I did notice a blue patch over a hole that, on examination appears to be a weep hole for evaporating moisture. (Photos below).
After dumping the water I left the lens assembly open in the sun for several hours to dry out.
The gasket on the lower bulb is “hard” so I used a bit of painters tape to improvise another layer of gasket material.
It’s all back together. I’ll see what happens the next time it rains. Tap-a-talk does not sort photos in order, so these are random.
Homegrown gasket layer
Different angle on the painter's tape application.
In this photo the lens assemble is literally full of tap water (took about 1.75 quarts, for those with inquiring minds). Notice the round, aqua blue patch over the hole that is seeping moisture. There is one for each of the three sections, and they appear to allow moisture to escape.
Sent from my iPhone using Tapatalk Pro
