I recently replaced my stock wheels with 24" rims with 305-35-24 tires. Im not sure if I need to get an alignment done because of the modification. The ride is still good but because of the MOD do I need to get an alignment done? Thanks
Wheel and tire replacement will not alter your alignment. But like BB said, it is good to get it checked. You want to protect that high dollar investment and get the most amount of life out of your tires. Nice pics in the PG BTW
Changing tires alone won't mean alignment, but if you changed wheels with a different off-set, you might need to re-check the toe...but even then, it's very little change if any...
