1 - 3 of 3 Posts
Has anyone with the bench seat noticed any problems with the power outlet on the inside of the console? Mine stopped working and I can't seem to pinpoint why (checked/replaced the fuse but it still doesn't work). I took out the center portion of the bench and noticed there is a female connector that isn't connected to anything and thought that may be the culprit but I can't seem to find where it would go so I'm wondering if the connector is prewired for some other use from the factory. Otherwise, my guess is that a separate connection some how came loose.
Karl
gtshouse said:
Not to insult you or anything, but I guess you've got the key on when you're trying it? It doesn't work when the key is off.
No insult taken, but I did have have the key on when trying it and no dice.
Karl
1 - 3 of 3 Posts
