Hi All,
2008 4WD LE
Trying to chase down a steering wheel wobble that can occur anywhere between 30 and 65 MPH. I've tried new tires, new rims, balancing, road force balancing, rotating tires, replacing sway bar end links (those helped tighten things up and make them more obvious, but didn't fix the wobble), inspecting tie rod ends (inner and outer) and wheel bearing inspections. Everything is high and tight.
This shake will come and go at times.. sometimes cornering helps (almost always right bends...)and it will go from a shake so bad you can barely hold on to the steering wheel to completely glass smooth in a 5 second corner. Left turns typically induce the shaking. Right turns typically make it go away. (although not always). All of this testing is using speed control. Speed doesn't really matter other than if you slow down to less than 30 MPH or so, it will generally go away. Last note, when the shaking is occurring, the vehicle typically pulls slightly to the right, even if i'm below 30 MPH. Just feels straighter when it's not going to wobble... I know that's hard to explain.
SO, my next thought was lower control arm bushings. I got underneath and found that on the front driver side, it was evenly spaced between the bushing and the mount, but on the passenger front bushing, it was rammed to the front. So I did some reading and found that some people suggest turning the wheel all the way each direction, and checking for movement. Below is what I videoed, and I think that it ended up in a different place than it started... this can't be right correct?
https://youtu.be/pQ7dfrMM-yk
ANY thoughts appreciated... I love a good challenge, but this one is driving me insane
2008 4WD LE
