Import
Yes, we have the same leak. After my initial post on this thread, I asked the dealer to pressure test the system to see if my heater core was leaking. They pressure tested the system yesterday to 16 lbs and said there are no leaks. Then I noticed the hose last night, which I am sure wasn't there before, and then tonight the main black hose running from the radiator to the engine I noticed has antifreeze caked on it. No wonder I smell coolant! I know these guys aren't pulling down big bucks but clean up after yourself when you are done! Now I don't know if the mess and the leak on smaller hose was caused by the pressure test/messy mechanic or if they are really leaking!
Thoughts/comments on spraying the engine down with water to see if the leaks come back? I hate spraying the engine down with all of the wiring under the hood.
I do not know if this is the tranny cooler line in my pic and in imports (tranny cooler used radiator coolant, correct?)
thanks
white
