Hello all,
I have a problem with my 2011 Titan, I had to replace the AC condenser and while i was at it i replaced the radiator with a CSF. Since the install the trucks coolant temp goes up to 220 at idle and having the AC at full blast. I bleed the system already about 4 times, I replaced the radiator and reserve cap with OEM ones, my antifreeze levels are at max in the reserve and full in the rad. My fan is working and on when temp goes up. I don't know what else to do!!! Do you guys think i need to replace my thermostat? Any ideas, any help will be appreciated.
Thanks,
Thanks,
