I brought a 2in level spacers prg, used off here. I didnt get the bump stops and the copper pins with the spacers. Now the guy i brought them from said he wasnt using bump stops and that the copper pins are a one time use. Can i go some where local to purchase the bump stops(if you recommend i should use them) and the copper pins??? thank you for the help.
you can go to most any auto parts store for the stops. I bought mine from Autozone and they were like $12 you just need to tell them you need energy suspension bump stops that are like 2" high. You will need to open up the hole where the stock ones are a tiny bit but they will bolt right in. Also dont go nuts tightening them down or you can pull the bolt out of the stopper
copper pins? you mean cotter pins? The ones from the bolt that connects the uca and spindle? you can buy cotter pins at a hardware store, or home depot/lowe's.
OMG, copper pins, ROFLMAO THAT MAKES MY DAY!!!!!
I believe what you are talking about are known as cotter pins. You can pick up the bump stops and cotter pins at your local auto parts store for under $20. Yes, you do need stops as it prevents damage to your suspension when bottomed out.
